Im using a rover 800 stainless oil feed and Mocal electric scavenge pump. As mine is a valver engine there were already holes from the oil level and oil temp sensors.
if you fancy a trip down, your more than welcome to have a look over mine, and take any pics you may need if that will help you in your project. im near stansted airport if its any use.
t-piece from the oil pressure sender hole (quite commonly used in OEM applications) or use a sandwich plate between the block and filter with take-off ports in it.
no, oil needs to drain into the sump above the level of oil. If it doesn't you will almost definitely get a backfeed of oil and the turbo core will be over oiled and pressurised which will cause the seals to fail
