edit: with the contamination point, shouldn't it be in a controlled environment anyway?
No but it would be nice to go tell my mate he's talking s**te
hes always right dontcha know! :banghead:
I've heard loads (from painters) about the angle and direction you spray metallic paints so it doesn't look a different colour. Then again the painters I know are useless f**king c**ts!!
What I couldn't understand was the point my mate was trying to put across, I just accepted it as a matter of course as he has more experience with painting than I do.
logically his point made no sense to me so yes I can understand that it would make no difference. My mate isn't on drugs
Metallic paint can change shade by painting with a different air pressure at the gun, lay it on wet and the metallic lays flat giving a darker shade.
Lay it on dry and the metallic stands up giving a lighter shade, we used to do a "drop coat" to stop "ghosting/cloudy" in light blues/slivers and other light colours.
That was over 12 years ago now so i don't know if things have changed with water based paints?
Which is why I couldn't understand his point.
good to know I can now go and tell him the next time the subject comes up that he's talking shite
Ia that what you do Gally, bodywork?
Our colour library is probably one of the biggest physical libraries in Britain. Reps are shocked when they come in and see the amount of colours and shades we keep.
We do pride ourselves on our paint matching. We actually have 32 shades of the White Pearl on the Laguna Coupe probably the most we have of any colour, FRS Ultimate green is always fun, like painting with Milk ffs!
We keep these colours we never through out any spray cards we do of colours. Just to give you an idea.
Sorry mate was just a passing comment.
With 3 stage pearls the actual pearl itself that is applied over the ground coat (green in this case) is very thin and opaque. It provides very little "coverage" so takes many coats to actually get the correct shade etc.
Electric Orange, Velocity Red and many others.
Ah I see i'm not sure "dry edges" is the correct terminology chap it implies something is wrong with the panel finish.
Every area that could be coated, was. As you'll see the 2 front wings, which i'm sure you're speaking about needed so little basecoat (colour) the rest is lacquer.
The picture with the bolds and rivets are sort of misleading. I explained in the text. The bolts were only temp for strength and testing. They were actually through the holes where the screws (torx) were used upon build up, I see what you mean though. All original bolts were re-fitted.
The bumper was far from easy to remove, partially due to the previous repair.
paint the meg? I'll bring Peroni.
Erdinger, keep up!
FFS, kids. I was trying to show off truth be told he'd have warm carling and chippy from me.
Flol! You don't come North!![]()
