Clio wheel help?!?!
Car  Renault Clio
I got a set of seat arosa wheels dirt cheap, they’ve got loads of tread and hold air (the current wheels on my Clio suffer from both of these). They’re 4x100 but don’t seem to fit at all, is this the case? Or do I need new bolts to fit these wheels?
Welcome to the Forum. If the wheel won't stay in place it could be that the centre bore is too small to go on the hub?
More info on which Clio you have and specific details about how the wheel is not fitting will help with diagnosis.
Thanks for the welcome!
just got a standard Clio 58 plate 1.2 petrol, I’ve attached a photo of the wheels.
they go in a bit wobbly and when putting the bolts on it feels like they aren’t reaching into the hub? Hope this helps?
The centre bore (CB) of the wheel is probably too small for the Clio hub (Clio hub is 60.1mm).
Grab a ruler and measure the gap on the wheel (circled red), anything less that 60mm is a no-go I'm afraid.
