clunking noise
Car  182
Evening all..
Just after some pointers. My 182 has started making this clunking noise from what sounds like under car towards the center but could be wrong.
It happens if say i stall the car or if i go over a sudden bump such as mounting the kerb etc but strangely doesn't do it going over speed bumps. Any ideas
mine does the same. Sometimes when slow 90° turns as well. Have been under the car, checked pretty much everything and cant find an obvious thing.
everything is tight, its just annoying knowing its there somewhere.
changing up a few things soon so hopefully it goes.
Mines all ways done this kinda clunking sound I recon it's the pass side drive shaft . changed most other things .
I just replaced the entire wishbones with a set with black powerflex fitted.
Takes a good 2 hours or more per side and is a right pain to do. But not too hard
yeah it is annoying. Mine does it when pulling off and turning at the same time and when slowing down to a junction. Its not all the time though, its just sometimes. Does my nut in.
got EML light on again now due to the exhaust blowing in guessing. Still running fine.
