Clutch and engine due to dead battery???
  Iceberg 172
I have a mk2 172 60k.
Last night when i went to start the car the battery was dead, i got a jump start and everything seemed fine. I was driving down the motoreway and all of a sudden all of the lights on the dash started flickering. Once i sped up they went steady again n non of the indicator lights were on but when i went to change gear the clutch went stiff like it is when the car is off. I pulled into the nearest car park and went back this morning and changed the battery. When i turned the ignition on the clutch remained stiff still and when i put my foot on the accelerator nothing happened, it didnt rev whatsoever, the engine just remained ticking over. I turned the ignition on and off and after about 4 attempts it began revving. I drove home but the clutch remained stiff all the time and when i reached about 4500 revs the engine was making a clunky sort of noise. Does anyone have any ideas what the problem could be and how after the initial problem seemed to be the battery it has turned into this?
clutch stiffness is not linkd to anyhting electrical so if that stifer its just because its stiffer and your noticing it more whe n the cars actin up
best off get the car to a garage the stiff clutch could be a clutch failing or stiff cable this could be leading to the trouble not the engine acting up
