Just had a new clutch cable fitted on the valver as it decided to snap the other week!
Is absolutely fine half the time, goes into gear fine and everything like normal.
But the more you drive it (after 10/15mins) the gear changes start to get a bit notchy and the biting point is right at the bottom. 1st gear is then sometimes hard to engage, and reverse crunches a bit and is then sometimes pulling when the pedal is on the floor....
Next time I drive it's fine again...but only for so long.
What's up? Is the heat from the engine affecting the cable anyway?
Thanks for any help....
