Clutch Problem 1.4RT
  172
Hi, my clutch has been annoying me so i decided to get a new clutch assembly.
Basically there was like 3-4cm in the pedal before any pressure is felt. So I assumed it was the rachet system or springs.
However if i try and adjust the cable (to remove any slack) with a say 0.5 cm washer at the cluch arm side the slack in the pedal goes away BUT i'm left with a strange feeling pedal, it kinda has 2 stages to it which makes it undrivable really. it goes about 3/4 down then more pressure is felt for a split secont then the rest!
So I doubt a new cable would sort that out. So with a new clutch installed the pedal bites right at the very bottom which sometimes makes it hard to change gear, especially reverse.
What's the problem with it? Why is there so much slack before the rachets bite?
Oh and installing that clutch assemble was the most annoying irritating thing i've ever done. The only thing that comes close is when I had to get the exhaust manifold of my mini
TIA
Posted on another forum too but i thought I would ask here incase anyone had a similar experience.
