Coil pack and Plugs...
J@Y
  Clio 182 and CBR 600
My 182 has developed a missfire/running on 3 cylinders.
I don't know the last time it has a plug change so I'm going to ordr a new set of plugs and coilpack.
My question: Do the 2.0 litres have 1 coilpack, 2 or 4 indivdual ones?
Also, where is the cheapest place to get these items from and how much should I be looking to pay to avoid being ripped off? Thanks!
  Golf GTD Mk7
1 coil pack. Second hand would be cheapest, but any eurocarparts/GSF i'd imagine.
where you based jay? Might not be coils.
  RB FF 182
If it is a spark/coil issue I got my plugs off eBay. The 1*2's are really funny about which plugs they run on, NGK Platinum something or other... do as search and you'll find the right ones.
J@Y
I'm from Rainford, near St Helens but I actually work in Chorley! Do you have any spares mate? Plugs of coil I could buy off you?
J@Y
It's a 182 mate not a 1.2...
I can't just wang any old cheapo plug in there then? Best gettin them from Renault?
Problem is I need them ASAP as I need the car daily for work :-s
Do they use a single coil pack or seperate ones for seperate cylinders?
  330i. E30 Touring.
1 coil pack (mounted on the upper inlet) and leads that run from there to the plugs..
  RB FF 182
1*2 is an abbreviation which means both 172 and 182... :)
I've heard they run like shite if you use cheap plugs. I got a full set of the recommended NGK ones off eBay for about £35 I think.
Do a search for spark plugs on here and you'll find the correct ones.
jenic
I have a spare coilpack you can have for a tenner, you'd have to collect it though.
Your throwing parts at it. It could be any of the ignition components, or even a lambda sensor! Do you have a fault code? If so get it checked and replace part accordingly.
