Coilover Fitting to a non-sport.
Car  TT 225
Thinking of fitting some coilovers to my non-sport this weekend just wondering if you suggest me getting spacers? Android said he has 5mm spacers but even with them his tyres rub on lock. Is it worth getting 10mm-25mm hub-centric spacers to prevent rubbing? the tyres i use are 185 55 15 so i dont know if this helps? cheers adam
but i was told it rubs, is there any way of preventing this? like removing arch liners or adding a particular size spacer etc?
It will catch a bit but nothing much just check after a bit see whats worn there a rear little arch liner plastic slip which does wear so mayb cut it down a bit
