Quote: Originally posted by crono33 on 02 March 2004
i think one of the reason for using coilovers is the fact that it is possible to fit adjustable top mounts to set up the camber
the struts in the pics also have very thick shaft, which makes for a more robust suspension
lowering is not the reason. lowering on road cars is often just a cosmetic improvement. suspensions have a geometry that must be retained. lowering more than a few mms usually upset completely all the suspension geometry and CV joints lifespan. not to mention the stresses on the bodyshell.
also adjustable hydraulics dont have much sense. hydraulics must be adjusted when changing spring rate or car weight. but there is only one narrow good setting for a given excursion, spring rate and vehicle weight.
motorcycles have ususlla fully adjustable rear suspensions because the payload can vary greatly, from one skinny rider to two fat assed ones.
some little adjustement can be useful to compesate the shock aging.
some aftermarket shocks are adjustable sipmly because they fit on different cars, so the manufacturers dont have to produce too many types of shocks.
gm
You can fit adj (pillow) mounts to non coilover setups aswell.
The goemetry you refer to isnt a perfect setting. Its arrived at through alot of testing on alot of surfaces, and is there to provide good handling with compramise.
You can change the std geometry settings to reach a far better handling car, but less of a compramise and possibly harder for different drivers to get one with.
And the narrow settings you talk about.....there are many settings you can run and, to what is best depends on what either results in the fastest lap time, or what the driver is most comfortable with. All you are trying to do is to keep the wheel in contact with the ground, whilst not deviating off due to irreguarities on the surface.
There is plenty you can do to result in a car you prefer the handling to, but when were talking competitive setups, then having precise knolwdge on what your doing is important.
With modern tyres, its typically most important to keep even contact and temperture spread, so damping rates/springs rates, geometry cahnge with roll and corner weights/diagonal weight percentages all require a totally different estup.
F1 now, especially with michelin, design around the tyre....it provides most of the suspension and all of the grip. Teams runnin michelines are told that they HAVE to adheire to a specific theory or flat running with no camber change to acheive peak performance. Unlike bridgestone whos tyres are more profiled and can run with camber....michelines are square and designed to run square.
I wouldnt get to fuddled up worry about suspension, as you can always improve for your intended purpose.
