Coilpack only comes with the leads attached IIRC. Parts4you or something similar were doing them for £50 last time I checked. As for fitting it's only four screws and a bit of twisting IIRC.
Pull off the engine cover and it's the 4 leads going between the inlets. The wires go left to a small block behind/next to the oil filler cap which is screwed in and has one plug connection. That's what you want!
The 4 long plugs just pull out, and they'll be stiff but twist/pull wiggle they'll come. They're only attached to the spark plugs on the other end so not screwed in etc.
