Coilpack 1.2
leeds2592
  Bean 182 + E70 X5
Hi,
Found out that I need a new coilpack for my 1.2. Just got 2 Q's.
Is it just the coilpack I should buy or the coilpack with the leads?
How do I go about fitting it?
Cheers :)
Coilpack only comes with the leads attached IIRC. Parts4you or something similar were doing them for £50 last time I checked. As for fitting it's only four screws and a bit of twisting IIRC.
maynard
  ph2 172 track car
Yep as long as it's a 16v.
leeds2592
  Bean 182 + E70 X5
Yep, mines a 16v. Some of the pics I've seen only show the coil pack without the leads, they must be 172/182's.
Where abouts is the coilpack located?
Thanks for the replies.
  DCi 100
Pull off the engine cover and it's the 4 leads going between the inlets. The wires go left to a small block behind/next to the oil filler cap which is screwed in and has one plug connection. That's what you want!
The 4 long plugs just pull out, and they'll be stiff but twist/pull wiggle they'll come. They're only attached to the spark plugs on the other end so not screwed in etc.
leeds2592
  Bean 182 + E70 X5
Alright, gonna get searching for the coilpack and hopefully get it fitted this week.
Thanks for the help :D
  DCi 100
I think I got one for around 28 quid from Eurocarparts, could try GSF if thats closer. Pay attention to the numbers on the leads.
leeds2592
  Bean 182 + E70 X5
Had a look on Eurocarparts yesterday but the ARC one for 28 quid is out of stock. Gonna give the Leeds branch a ring, see if they've got it.
