Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Coilpack only comes with the leads attached IIRC. Parts4you or something similar were doing them for £50 last time I checked. As for fitting it's only four screws and a bit of twisting IIRC.
Pull off the engine cover and it's the 4 leads going between the inlets. The wires go left to a small block behind/next to the oil filler cap which is screwed in and has one plug connection. That's what you want!
The 4 long plugs just pull out, and they'll be stiff but twist/pull wiggle they'll come. They're only attached to the spark plugs on the other end so not screwed in etc.
