Coilpack and leads ?
Hello
I'm about to buy the above but was wondering what makes people recomend.
Is it worth buying uprated style leads or go for originals and with the coilpack do I go for genuine or a motor factor one.
Any advice and where best to buy from would be great
thanks
  172 Cup & Mini C 1.6
Keep with the original leads mate dont bother with magnecor leads my mates 172 misfired like a mo fo on them
I had a look into the Magnecor's and after a bit of investigation it appears that all the problems relate to the 8mm blue leads, not the 8.5mm leads. Can you confirm which he had? Jon
  george 172,205,metro
magnecor leads should be fine but always use genuine coil packs as the none gen stuff fails very quickly
Ok thanks for the help lucky I asked as was going for magnacor. Do ktec sell genuine stuff only my nearest Renault is 30 odd miles away so I'd rather order from somewhere that will post the correct stuff out first time. Or anyone else that are recomended.
Ive just got of the phone to him and yes he had the 8mm leads
  Megane r26
I ran the 8.5mm magnecor an never had a problem.
Nick (from the old hill power) always to recommend them. He always said the standard leads were a bit naff, he seemed to think the fact they were bunched together in that sleeve they would be more likely to cause interference with each other.
