Colour coding
  Clio
I have a black 1.2, i want to colour code the side strips, 172 rear insert, and front mouldings. I have done my front and rear badges which came out really well.
However is there a guide on here for colour coding the car, as im unsure if im able to get rid of the orange peel effect on the plastic.
On a scale of 10 how hard a job is this?
Thanks.
not a hard job to 'fill' the grain, just time consuming, building up lots of primer and flatting
never will have a perfect glass surface finish, just take your time
if you are unsure, why not get some parts from a scrap yard and see how they come out plus you will get a bit of confidence, cheaper than going to a body shop which ever way you look at it
go through the grades of wet n dry on the textured plastic... it'll soon go. Don't use high build primer, its a pain in the arse.
What grades would i need, also would i have to sand by hand or is there a quicker method?
then simply add 3 layers of primer, 3 layers of colour, 3 layers of laquar?
take em off sand with about a 120 grit
wash off with alcohol based cleaner
plastic prime them hi build prime
flat with 800 grit
paint + clear coat they will go flat so sand with 1500 then polish with G3 (like t-cut)
simples...
