Andy_con
clio 182
following this guide
http://talk.maemo.org/showthread.php?t=82693
am on this part
PREPARE TO FLASH
On Windows, open a Command Prompt with Administrator permissions (with UAC,
right-click Command Prompt and select Run as administrator). On
Linux, open a root shell (sudo -i/su). Change to the directory containing the firmware
images you downloaded.
On Windows, run set
PATH="C:\Program Files\Nokia\Flasher;%PATH%" in order to add Flasher to
the system path.
but its not working, help?
am on this part
PREPARE TO FLASH
On Windows, run set
the system path.
