Command Prompt Help?
Andy_con
  clio 182
following this guide
http://talk.maemo.org/showthread.php?t=82693
am on this part
PREPARE TO FLASH
On Windows, open a Command Prompt with Administrator permissions (with UAC,
right-click Command Prompt and select Run as administrator). On
Linux, open a root shell (sudo -i/su). Change to the directory containing the firmware
images you downloaded.
On Windows, run set
PATH="C:\Program Files\Nokia\Flasher;%PATH%"
in order to add Flasher to
the system path.
but its not working, help?
Andy_con
  clio 182
Is 'flasher' the program you have downloaded? It isn't a built in windows application so it will not recognise it.
Try switching to the directory of the folder that 'flasher' is in. (the set command should do this but hasn't worked)
Try
Code:
SET PATH=%PATH%;c:\Program Files\Nokia\Flasher
Also make sure that folder exists
Andy_con
  clio 182
am using w7 64bit
ive installed the flasher program yes
flasher is currently in a folder on the desktop, ill move it
  mk1 Octavia VRS
Try this:
Code:
"C:\Program Files\Nokia\Flasher\flasher.exe" -i
Not on a Windows PC at the moment but I think that should work.
Andy_con
  clio 182
sorry to be a pain, this is really taxing my brain!!
the next part, ive moved the files into the same folder as the flasher. what command line do I use?
Note that you should replace main.bin and emmc.bin in the commands with the actual names of the
image files you are flashing.
Replace operating system (preserves user
data)
The following command will replace your phone's operating
system with the supplied firmware image. All applications will be removed, but
music/documents/maps/etc. will be kept. This is equivalent to updating/restoring
your phone using the Nokia Software Updater (NSU) utility.
Code:
flasher -f -F main.bin
Andy_con
  clio 182
file names are-
DFL61_HARMATTAN_40.2012.13-7.UKIRELAND_EMMC_UKIRELAND.bin
DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin
Right ignore what 172 tom put above, you need to set the directory to make things easier. either use set or cd. I've gave examples of both above!
Then
Code:
[COLOR=#333333]flasher -f -F [/COLOR][COLOR=#333333]DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_001-OEM1-958_ARM.bin[/COLOR][COLOR=#333333]
[/COLOR]
Andy_con
  clio 182
let me just be clear, I don't get command prompt ;)
use set or cd???????????
where do I need to store the flash files? currently they are on the desktop. that's just where I happened to download them
Then
Code:
[/COLOR]
move the files to C:\Program Files\Nokia\Flasher
Then use the command cd \Program Files\Nokia\Flasher
Then run the command in my above post!
Andy_con
  clio 182
that worked many thanks for spoon feeding me ;)
grrr battery isn't charged enough now to flash lol
Andy_con
  clio 182
f**king not, phone wont start up and the battery wont charge.
so I cant flash as battery it to low, how w**k
many thanks for your offer
Andy_con
  clio 182
plug the charger in and vibrates, nothing on the screen. then almost restarts vibrates and again and just keeps going like that forever
Andy_con
  clio 182
whoop whoop the n9 is back to life
many thanks, time to ebay :( that a sad day. best phone I ever owned
Andy_con
  clio 182
bugger its not working, just getting the spinning wheel of loading. looks like its going to have to be a full flash
