convert standard clio 182 sport to cup suspension?
  clio182 sport ff
Is it possible to add the Cup suspension packet to Ph III Clio 182 Sport afterwards or was this an option at purchase?
  RS Clio 200
dunno, but i wouldnt say its worth it... just get proper coilys if u wanna do the suspension
  Turbos.
Does the Cup also have different hubs?
As said, will be cheaper to go aftermarket, unless you find cheap second hands stuff.
Yes and its not worth it.
To do a proper conversion you'd need
Hubs
Shocks (£200 there alone)
Springs
You could use the old hubs and use comber correction bolt or drill the 182 Cup packed shocks to fit at the front if you wanted.
Yep different front hubs stock ones could be made to work though.
Your right aftermarket coilovers would be better than 182 Cup stuff.
Your lucky that your hubsare the same as the normal 172 ones so so logna s the coilovers you buy have enough adjustment for camber correction they'll fit fine. Thats means there a greater choice out there for you.
