Converting HID Back to standard
Car  clio 182 cup
The shitty after market HID dipped beams are more trouble than they're worth on my 04 182 and I want to convert them back to standard.
Can anyone point me in the right direction for what connector I need for the standard bulbs once I've removed the HID ballast?
Thanks!
If they are separate High Beam and Dipped Beam, dipped beam is probably just an H7 connector?
You'll need to look at the current bulbs to see what they're marked as - presumably they will be H7 (or whatever) because the hole in the back of the headlight won't have changed.
