cornering left better than right?
  • Thread starter Thread starter kunit
  • Start date Start date
K
kunit
my ph1 172 seems to go round left handers better than right. turning right i get understeer. i have set the car up on top spec wheel alignment equipment and all angles are within tolerence just wondering if anyone else has experienced this or im just being weird?
chris
are any of your tires more worn than others, eg much more worn on the left side of the car?
check tracking etc, des the car pull left or rite when ur on a flat road etc etc
I would check tyre pressure first off especially in this weather, i run mine a couple of psi lower in the winter. Check your tyre tread too. Just the obvious things out of the way first. Also are you sure its not your driving...?
firstly check tyre pressures, next check the dampers to see if any are leaking and lastly do you have 4 tyres the same or at least 2 front the same and 2 rear the same (i always try to replace in pairs)
