Van
I found myself here on CS.net whilst searching for a model which could be used on track on a relatively low budget. There seemed to be a wealth of knowledge and a well proven reputation for the Clio RS, so I did a little research then went out and bought a 172cup.
Its a 69k - 6 owner gem with a dent on every panel, and it would be fair to say that it's been a little neglected just recently, but that suited me just fine as it was local, fairly priced and perfect for what I wanted it for.
So, I got it home then went out the next evening and bought a Sabelt Seat and Harness for it, stripped it out, fitted the seat and welded in a harness bar.
Had to get a more focused steering wheel and boss for it, so in the spirit of the car opted for a cheaper one than I normally would, which actually turned out to be very nice.
Oh, Seat is out of an EX works C2 so has Citroen branding, but again not something that bothers me. Although I do sometimes accidently now refer to it as a Saxo :S
Started to do some servicing as there was an almighty clunk underneath on its test drive. I was quite happy that it wasn't serious so just mentioned it when haggling, and it turned out to be inner and outer track rods/ends.
Made up a tool and swapped them over
(Cup ones are dealer only but found some Kangoo ones which were the same and stocked at Motor-Factor)
Whilst I was under there I noticed it had a full 2.5" K-tech stealth exhaust, Goodridge braided lines and a powerflex'd rear gearbox mount which was all a nice bonus as it wasn't advertised.
Then turned the attention to wheels and tyres. The 16" Turini's had to go, and I got lucky with a PH1 Exclusive in a breakers yard so nabbed the BBS
7j x 15's off it and fitted some part worn 888's for a dry set.
Then bought a set of 6j x 15 Sparco Cromodora's with T1R's which Il use as wets just for now, although I shall swap them for Rainsport's as soon as possible.
I fitted the Sparco's this morning for a few pics, but one will need to come off again as randomly there are 3 lefts and only 1 right :S
And that's it for now. I have Castle Combe booked for a full day this Friday and ideally I would like to get the ride height sorted by then, but if not at least Il have a comparison for next time its out. The CookSport springs are out of stock so not holding out any hopes to be honest, although they are local so if I can collect some Il be very happy.
Laguna splitter will be going in the bin but Il still replace it, just with something a little more subtle.
Thanks for reading.
Thanks for reading.
