As above the updated crank sensor plug has a pink and pale yellow wire. which is positive, which is negative? Im trying to wire it into my standalone ecu loom but obviously want it the right way.
Well if it helps white goes to pink on the new connector the two pale brown go together. If I remember the pins are marked pos and neg on both new and old connectors.
