Cup Pack Fitted
Car  Megane 230 F1
Ok - I bought Towzer' 182 back in March, but neither of us can tell if it's got the Cup Pack suspension or not. No point posting photos as it had (at time of purchase) lowered springs and Turinis on it.. One of the rear shocks has decided to start taking a leak so I need to replace them - is there a way to work out if it's cup-packed suspension, any identifying marks.
It does have the cup spoiler - but it's missing the log/purchase books and there's no oval plate either.
At a loss really - anyone?
Cheers.
You can tell by the distance of the hub bolt spacing but cant remember what it is.
However, i'm pretty sure the rear shocks are the same...
front hub bolt spacing on the cup suspension is 60mm, i think its 54 or 56mm for the normal
its the only way to know for definate but as said i think any rear shocks will fit any clio
as said^....
pop the front wheel off and measure the distance between the shock bolts center to center, if its 60mm you have the cup pack suspension, if not, you dont..
I am having a little issue here..
just went today and picked up my 182 front cup shocks from the dealer and on the box it says 8200342845 which is fine (as this is the correct part no.) and the space between the holes is 60 mm-which is fine also but on the shocks is punched 8200681109 which if I remember correctly is the non cup part no. any ideas?
