Cup Suspension
  Renault Clio 172 Cup
I have a 172 cup, ive purchased some coilovers but have since been told they wont fit my car as they are for everything apart from cup? What is the difference?
  172
The spring/damper unit bolts to the hub with two bolts.
The bolts (or rather the holes on the hub) are 54mm apart on the cup and 58mm apart on the non-cup suspension. (IIRC, the numbers might be backwards) This is why they will not fit.
You could have the coilovers modified, but it's only worth the effort for expensive coilovers.
  182
So much fail in here!!!
172 ,172cup and NON cup/cup packed 182 have 54mm spacing
only 182cup /cup packed and trophy have 60mm bolt spacing
  172/B8 Quattro
As I said in my post ;)
This is the correct info here don't listen to owt else (even part numbers on dealer sites)
