Cup to 172 Phase 1
  EP3 Civic Type R
Hiya folks,
Had a search but can't find out for sure, but out of interest will 172 Cup suspension fit on a Phase 1 172 and vise versa?
Just have a few mates after some info!
Ta,
Mish
  EP3 Civic Type R
That's what I presumed...as far as I know the 'basic' setup is the same, with them all having 54mm spacings etc...
  LY 182
yep should be fine mish..
not that it affects what your after, but the hubs are different (same bolt spacing as you know though)
  EP3 Civic Type R
What's the difference with the hubs then? May as well ask while it's in conversation so I can tell my friends I was right in the first place!
Thanks guys btw :)
  RS RIP
hubs are the same
The wider track from the Cup 172 is only because of the Turinis different ET value
The 182 has the larger hubs
  172 Ph1/Scooby MY00
I've just fitted the front struts for a 172 Cup to my ph1 172. The bolt spacing is the same on the hub. Only problem with it is that it now drives like a dog! Just needs the tracking doing hopefully.
