Cup Tyres
My Cup has just gone past the 2500 miles mark and Im slightly concerned to see the front tyres are already showing quite noticeable wear..... I use the car mainly for motorway driving and also a bit of dual carraige way and roundabout action and like to give it a fair bit of welly when traffic permits. Would like to know what sort of mileage one should expect from the factory continentals and also what, if any are the problems if you swap fronts with backs?
One other thing, was sitting in doors a few weeks back and looked out to see some huge hail stones crashing down... felt this was unusual at the time!! Anyway, gave my car a good polish at the weekend only to notice the roof and bonnet have a dozen or more very small dents!!! Can you believe that!! the good news is, my friend who has an RB5 Scoob just down the road also suffered the same fate!!! I guess it adds character to the car though still a bit piss*d off!!!
I changed mine at about 11k too...they could have gone another 1,000 or so, but I wanted a fresh set for a track-day.
Swapping front to rear? Many people will tell you not to do it, but if youre comfortable with controlling the car should you get a little lift-off-oversteer due to reduced rear-end grip, then theres really no reason not to. To even out tyre wear Ive been doing it for years...
I swapped my fronts with the rear at around a 8000 or so miles and since then the fronts (old backs) still have loads of life left and im just over 11000. TBH i havent noticed a huge difference in the handling of the car since the change, if anything ive pushed the car more since. Ive done this on all previous cars as i couldnt afford to replace fronts so often. But then as markcup says its up to you and how you feel about doing this.
my fronts and rears were ready for changing after 9k, thats without a front to back swap! :oops: What can i say, i like to drive her hard! To be honest the fronts were only just legal, and the rears had less than a 1k left on them, so i just decided to go for 4 new ones.
I went for Uniroyal rainsports, and although they give great grip in the wet and pretty good grip in the dry, and a lot less tramlining than the contis they are a b**ch at motorway speeds, feels like im driving on Jelly. Think thats to do with soft sidewalls. Its a bit of a scary experience when you first notice it.
Max
I think you guys need to have a play with your tyre pressures - I normally have about 34/32 or 36/33 in eagle f1s cos of the softer sidewalls.
Ive removed my fronts this weekend just gone. Purchased another set of contis for the rear and put the wheels that were on the rear onto the front. If your fronts are too worn, then they wont displace water very well (even on the back) and you could be risking it a little, although I dont know how worn they are!
Where is the cheapest place to get hold of 2 Conti Sport Contacts for the CUP. 195/45 R16 80V. Cheapest so far is mytyres.co.uk at £57.50 each. Is that a good price? Anyone get cheaper than that?
Get your Alignment Checked - bad allignment will cause "unatural" tyre wear
If your doing mainly motorway your tyres shouldnt be wearing, fast cornering and lots of fast urban speeding will.
I got 12k from my first set of contis and 6-7k from the second front set, the original rears could have done 20k easy. If you dont plan to swap brand then you might aswell leave the rears where they are. Cups are so light at the rear theyll never wear out.
Also had F1s on briefly and Im sure they would have gone even quicker!! My current contis have done about 27-28k miles and the fronts are still ok even after a trackday...cant grumble.
Plus, theyre SOOOO easy to get squeeling on the round abouts its funny, the looks I get off some people:o
cant do much about hail can we, mind cant see it been that often that it is enough to leave marks on cars, maybe I am wrong though.
Just ordered 2 new Contis from mytyres that are the exact same spec as the oe Cup tyres.
Ive come to the conclusion that the Clio was set up using the Contis, so why change them?
Thanks for all the feedback people!! lets Face it, £57.50 each has to be worth it when you put things in perspective. I had feared new tyres would set me back no less than £100!!! Reckon I shall continue with generous application of the right foot from now on!!! Only wish there was a way of getting cheaper fuel....!!:(
I had the Contis on my 172. Only got 8k miles out of them. Have recently changed to TOYO PROXYS T-1S. MUCH better in the dry. interesting in the wet!!! Got 12k miled out of them on the front and they cost me £55 a corner. Look cool too.
Currently trying out the Toyo T-1R. Seem alot quieter and better wet grip and are supposed to last longer.
Lift off oversteer is a a side effect, not a driving technique. If it happens, its just the driver who cannot drive so i would see no problem in swapping front to backs. My backs look like new after 15k miles..
-Rob
Only downside in swapping backs with fronts is you end up buying 4 tyres instead of 2 eventually.
I actually see it as a technique Rob, perhaps not one best used for the road, but definitely a driving "technique" nonetheless.
On track, I like the ability to carry a higher turn-in speed at entry, knowing that a slight lift combined with some corrective lock, and balance on the throttle will get you out the other side :D
Mark
