Custom remap, what can be gained ?
A lot of people have asked me this question lately. To give you an idea what can be achieved on a standard (no mods) Clio 2 RS see the below comparison chart.
http://www.postimage.org/image.php?v=Pq1YTYBA
All 3 cars are standard ph2 CB15's and are tested on the same dyno, under the same conditions, same day. The most powerful RS (101 kW) runs a custom RSTuner remap. To be honest, the car with the custom remap has seen a lot of WOT action ;-), and I suspect the other weaker cars not so much. So peak performance between the cars may be a little closer than the graph is showing. However this doesn't apply to the midrange torque difference, which gets you moving in the first place.
NOTE: Actual numbers depend on fuel quality, barometric pressure and temperature.
What matters is the torque difference between these cars.
Custom remap, do I need it ?
if your RS doesn't see >6k on a daily basis, NO
if you think your RS is already extremely fast and you're saving up for a G-suit as we speak, NO
if you think instant throttle response might hurt you, NO
if you think JC gearboxes are known to disintegrate just by looking at it, NO.
if you installed cams,YES
if you want to get the most out of your mods and engine, regardless, YES
if you need to get out more during the summer time,YES
Custom remap, prerequisites ?
Laptop / RSTuner
2nd or 3rd gear wide open throttle data loggings from 2.5k – 7k rpm
engine under normal operating conditions, normal inlet air temperature and normal coolant temperature
Tank filled with a fuel grade you'll be using from then on
ECU not operating in degraded mode, meaning free of any fault codes
Usually it takes about 4-8 calibration (map) updates to get it spot on.
The actual data logging is really not difficult to do, but it is your responsibility to make usable data logs for me to work with.
I'm already running a remap, will I benefit from a custom mapping ?
YES, always. How much, also depends on the mods you have done. Some mods actually decrease power in some areas. That said, I cannot predict how much the gain on your car will be. Simply think of a custom map as ' icing on the cake'.
Video Clio dyno start at 3:13 min.
http://www.youtube.com/watch?v=Dy1nLoiUtYQ
Thanks to Jamie for making the comparison chart and using his heavy right foot extensively...
Laptop / RSTuner
