cutting out on low revs
You could try cleaning your throttle body.
Remove air box elbow and it's the thing bolted to the right side of the main part of the engine.
4 bolts and a electrical plug to remove it - clean with a rag and WD40 as the inside will be gunked up with old oil.
Do you not need a new TB seal when you put it back on or can you use the old one?
