PHASE 1 172 if i do not give my 172 enough revs it cuts out... what can be the problem??
r_dizzel* Vantage Aug 9, 2009 #1 PHASE 1 172 if i do not give my 172 enough revs it cuts out... what can be the problem??
A Aluco Titanium 182 Aug 9, 2009 #4 You could try cleaning your throttle body. Remove air box elbow and it's the thing bolted to the right side of the main part of the engine. 4 bolts and a electrical plug to remove it - clean with a rag and WD40 as the inside will be gunked up with old oil.
Dm_26 Aug 9, 2009 #6 Aluco said: You could try cleaning your throttle body. Remove air box elbow and it's the thing bolted to the right side of the main part of the engine. 4 bolts and a electrical plug to remove it - clean with a rag and WD40 as the inside will be gunked up with old oil. Click to expand... Do you not need a new TB seal when you put it back on or can you use the old one?
A Aluco Titanium 182 Aug 10, 2009 #7 Menzies_Clio said: Do you not need a new TB seal when you put it back on or can you use the old one? Click to expand... On a 182 it is an orange rubber O ring that is reusable. Older models need a new one from Renault.
