I was thinking of changing my w800 to a d600 but not so sure after reading a post of expansys with these d600 problems:
1. No voice recognition
2. No auto-answer
3. T9 doesn't use automatic capital after full stop
4. Phone studio has bugs in it (certain versions only)
5. Poor battery life on phones that have a J as the penultimate character in their software (*#1234# to check)
6. Some providers' firmware cause annoying side bars
7. Loudspeaker shouldn't have "loud" in its name
8. Flash can't be set to auto permanently
9. No option to AUTOMATICALLY save sent texts
10 If you accidentally press snooze, the alarm will go off in 5 minutes. Fine if you do want to snooze, however if you accidentally press it then there is no way of stopping the alarm going off (even when you do switch the alarm function off)
11. With the converter function, they have put the US (6pints) for the Gallon.
12. Can’t change the volume of the alarm
13. Scrolling through names by using first letter eg. 'g' moving up will go to f's instead of the top end of the g's
14. Phone ringtone quiet for first 5 seconds before going to proper volume - unreal!
15. Why did they make the OK/i button the WAP function when it blatantly should have been the menu?
16. No Vibrate and ring at the SAME TIME!!
17. When you view a picture on the memory card you can't just scroll to the next pic. You have to go back to the thumbnails and select the next pic you want to view.
18. You can't zoom on pics on the memory card.
19. You should be able to change the text message alert from the preset ones
20. Annoying tone & flashing when battery is low
now having 2nd thoughts! anyone got one?
2. No auto-answer
