Dashboard removal
Car  16v 1.2 Expression
I'm about to remove the dash form my Expression, so I can fit a new cable for the stalk controls. I've already read a few guides on here about how to remove it, but I've noticed some mention disconnecting the battery :/
Is this really necessary, or can it be done without bothering?
I never bothered and never had any problems... but it's only because I'm lazy. Just be careful around the airbags.
If you're really bothered then just disconnect it buddy only takes a minute or two! Although of course you should leave the car around 15 minutes afterwards before working on it.
Thanks :) I didn't bother in the end, and it all went very smoothly.
Although I now have another problem... After fitting the new cables and fitting my aftermarket radio I turned off the engine, just to find out that when I turned it back on the radio hasn't kept any of the saved settings. I'm not sure what I've done wrong, and annoyingly as I'm just starting out, I don't even know where to start to figure out what has gone wrong. If anyone can help I'd be extremely grateful
I'm guessing those were the red and yellow wires? I just popped down to a friend who explained that as it's a french car, they technically are the wrong way round for the radio. So one little swap, and now everything is good again :)
That will be the right colours, completely forgot what colour they were at the time of writing about them.
