Dci 65 Modifications
Car  Renault Clio Dci
Hello all, im a new poster on here, but been observing for some time now. I have had my Dci 65 for nearly a year, and after saving some money decided to remap it up a little. I purchased a K&N 57i Induction Kit, RS Tuning Remap (excellent work Paul) and a stainless steal Exhaust.
Since getting the remap, mostly in 4th gear 3500rpm> a yellow sign comes up (in the service manual says something to do with immobiliser) and i loose power.
I was thinking maybe it was an air intake problem, but im no mechanic.
Any Replies would be much appreciated
Bovie.
Yeah Like a Heart Monitor.
The person who did my remap is a Member of this Forum (P Murrey), so id thought id post it here.
I Dont know how much boost im running.
Well it is an electrical fault.
It may just be some of the connections in the engine are a bit loose.
A similar sort of thing happened to me and it turned out some silicone was in some electronics plug in the engine.
Sam
Bovie.
You need to get it to PM murry or a garage and get them to fault code check it etc when its running see what the fault code is.
If possible please get the fault code. As i remember you were also getting this problem with a tuning box you had fitted? Boost will be stock as they don't really need to run more on a stage 1 remap.
Paul
Dont know if anyone is interested in the thread still, but i took it to paul, and turned out to be a EGR? Valve. Brilliant Service spent 2 hours getting it out as it was stuck fast. Replaced with a new one. Now car works brilliantly, no problem.
Would recommend Paul and the Garage to anyone, and will probally use the garage for my clio from now on.
