Hi, i've just had my airbox off to have a look at the airfilter (02 dci 65 on 57k miles) and decided to clean the EGR valve while i was at it.
Thanks in advance
- When i took it out it was perfectly clean and dry however when i ran my finger into the inlet manifold it was stuck up with a gritty tar like oil.
- I had a further look about and noticed that the sensor on the hose from the turbo to the inlet manifold was also weeping oil.
- There's also a bit of old/dry oil from between the turbo halves (presumably the seal interface).
- I also took off the engine breather hose that connects from the plastic rocker to the inlet hose that runs from the airbox to the turbo.
Thanks in advance
