Sorry if this has been posted before :S
How easy is it to debadge the rear of the mk2 clio ?
Are the Renault, Clio and Sport badges clipped in with rivet type things ?
Or sticky backing pads ?
As i thought about doing it
personally i'd leave the badges on as you'll be baited into races by every1 not knowing you are a 172
renault sport are stuck on, boiling water should do it, then some tar and glue remover possibly if it leaves anything.
Clio one has two lug behind so you'll need a body shop to weld holes behind, fill then paint tailgate to do a proper job.
