Megane 250
I've recently bought a clio 200, but its down on compression.
Its also got a rattle on over run and fairly flat in the rev range, so I'm assuming it's not been timed up correctly.
My question is, will it not being timed correctly snd the dephaser pulley failing, cause low compression?
Cylinder 1 being the drivers side and then across to gearbox.
Cyl 1 - 150psi
Cyl 2 - 130psi
Cyl 3 - 120psi
Cyl 4 - 130psi
Sent from my SM-G975F using Tapatalk
Cyl 1 - 150psi
Cyl 2 - 130psi
Cyl 3 - 120psi
Cyl 4 - 130psi
