not sure if this has been asked before and iv missed it but iv had a search and couldnt see anything so here goes.
if i wanted to remove the dephaser pulley would i just need to block up the valve hole which sits in the head and use a solid bolt to stop the oil flow?
does anyone run standard cams with the dephaser removed?
or peep that run aftermarket cams have any of you removed the dephaser?
any advice welcome
any advice welcome
