Dipped Bulb - H7? (seen confilcting search results)
KitsonRis
Bulb has gone on the Ph2 daily (non-sport). Seen a few conflicting searchs to what it is. It is a H7 just to put my mind to rest so I can go get one. I would go and remove the blown one and check but it is dark outside to fiddling around the engine bay.
And why are they such a pain to get to?! Searching for bulb types and someone says to remove the front bumper just to change the bulb!
Also what would be pretty good is a sticky topic with the different standard bulb types needed......
KitsonRis
Sure I have some around in the spares box.
Not sure why I found results to suggest it was otherwise, unless aftermarket lights.
THANKS!!!!!!!!
  renault clio 1.4 16v
lol they wont take that long to change, i did mine in 10 mins... although it must be said a hot engine forces you to speed up the process 😂
KitsonRis
I tried for 10mins and with no success so I ended up taking the bumper off as I was sure it was going to be less hassle and quicker. Just amazes me for a job that should be done by any motorist regardless of technical ability and also done at the side of the road the easiest way was to remove the bumper!
Oh it was the drivers side that needed doing, passenger I could just about reach and do.
