Disabling passenger airbags on 172 Mk1
Jas
ClioSport Admin
Car  Maserati Ghibli S
To safely fit a baby seat in the front of the 172 I need the front passenger side airbags disabled.
Is this possible? Is it an easy/cheap job? Can they be re-enabled later on?
Any help please (before I ask my dealer!)
(and the mk1 172 doesnt have a key switch to switch them off)
take the dash top off and unplug it.
Unplug the side ones too.
The light will come on, but hey..
Id rather the light not be on all the time, but if thats the only way of doing it ill live.
It would be interesting to see if the mk2 switch can be retro fitted.
if you can get hold of the wiring diagram.......
Can you not just unplug it from under the passenger seat?
You will have to have the dash light on i think Jas.
can you not use the resistor trick that y0z used to fool the system into thinking there are airbags in the system?
Smokey, Im not sure if thatll do the job, theres the dash one as well?
CocoPops, Ill speak to Yoz, cheers.
This conversation was happening between a customer and the dealer when i was in the garage once.
Apparently Renault will not disable the airbag for the MK1, as it is a designed in safety feature, and sold as such. Also they will not alter the airbags on the MK1 or fit a MK2 switch, as the car has not been desinged this way, any alteration would leave Renault open to compensation claims.
He did say some backstreet garage could do it, but it would invalidate Renault warranties, and trade in values if the airbag has been tampered with.
Basically, it can be done, but Renault would not do it because of the possible compensation claims.
