Disc and Pads for Road use only
  "Navy" N17 TWO
They came with the car tbh;).
Your'e right OEM stuff is perfectly fine but it never hurts to have better if you want/can afford the premium. It's just the same as spending that bit extra for decent tyres over ditch finders which are still perfectly legal so must also be perfectly fine for most situations... If the upgrade cost £500+ to do then I'd agree with you but around £170 more isn't much really in the grand scheme of things.
The kid thing was just one example of where they could make a difference...
This is more-or less why I upgraded mine :)
  Clio 182
Just got Front Brembo HC Discs with Brembo OEM front and rear pads, genuine rear discs on the rear. All will be fitted on Saturday and let you know how I get on. Oh and ATE Super Blue brake fluid. Should be more than adequate for road use and the occasional track use.
