Maybe if I explain this in more detail
I have a Dacia Logan which is build with Clio 2 parts. The brake brake setup is as follows (with ABS):
Front: 259mm vented discs (identical to Clio 2 1.6 16v)
Rear: drums (a bit larger than the ones on the Clio 2)
I'm looking to increase the power of the car so better brakes are a must.
I've got two setups in mind:
1. All-around Clio2 RS brakes
2. Front 300mm conversion: Scenic discs and bigger calipers
Rear Clio 2 disc brakes
I know a couple of Logan owners who changed the rear brakes from drums to discs on their ABS equipped cars but had problems with brake balance, i.e. their rear wheels would lock up too soon and even with the ABS controlling the situation, the car would be unstable when braking and turning at the same time.
Is this something that would usually happen to a Clio 2 when doing a rear disc conversion? If so, is there any way to change brake balance?
