Disk brake conversion on my 182 REP
Car  A sexy one
im picking up a rear axle from a sport on friday :) to put on my 182 rep ;) im planning on just swappin the brakes tho! is it just a straight swap without the need to take the whole axle of? and how does the handbrake work on the disks as i have drums!? will i need to buy some parts or will it swap straight over?
It won't work with the ABS, different number of teeth on the drum abs rings vs the disc rings. And the whole axle needs swapping.
Short answer, sell the free one on its not worth the hassle.
number of teeth should be the same... the sensors will need to be ones from a disk axle tho. swap the axle over should be as simple as that
you'll need 172 handbrake cables
swap the entire axle though, and it does depend on which abs rings you have on your 1.2 axle, they will need swapping over if they are the wrong ones on the 172 (99% chance they will be)
Cheers guys, got the axle in the back of my car might invest in some new disks, rat style disks aint cool lol, il upload pics to my rep page :p
