Does anyone know how to change the speakers in a Clio 172 dash
Its a ph2, i was hoping it would just be a case of popping the tweeter cover off but thought id check to see if anyone has had to change them on here 1st
I think the tweeter cover does just pop off, it might be a bit fiddly that way, but not difficult, the tweet is directly below the cover so you just need to pop it out and change it over.
Taking the dash top off is not a difficult job anyway mate.
You can get the tweets out without taking the dash off, just you may end up swearing a lot while you do it.
Cover comes off, there's a tab in the edge of the tweeter closest to you (ie furthest from the windscreen), give that a shove, the tweet will pop out of its holder, now you've just got to wiggle and pull at it until it comes out.
Just dont pull at them!! You will break the 'teeth'. Its a bayonette fitment and the tweeter cover will twist one way or the other and then just lift out with no resistance. The tweeters are offset by about an inch though which makes getting to them difficult. Failing that the dash isnt too much of a ballache to get out.
Cheers, im not the most patient of ppl so might be easier 4 me to just remove the top of the dash rather than fiddle about trying to pop them out :)
