Does this sound goosed?
imprezaworks
Car  Mk5 Golf GTI :)
I wont go into a full depth story, so to shorten it. Passnager front driveshaft, if you hold that and the disc you can turn it slightly right/left and in and out if that makes sense? Drivers side you cant do any of the above. On track on tight ish right turns, vibration, bumpy, like driving on the alloy/uneven road sort of feeling. Also it has been rubbing on the plastic guard above the shaft that protects it from the body of the car, drivers side cover isnt there. Thoughts????? Oh and Ive ordered a replacement shaft just in case. I have asked a couple of people but thought id ask for a second opinion.
Dan
A little bit of in/out is ok but there shouldn't be any rotation play in the shaft, so yeah its probably fecked. Where'd you get the replacement shaft from?
Cheers. Ive ordered it from Josh at cliospares. Getting it fitted first thing Thursday am at Birchdown
Dan
Cool. Im convinced there has been something not right since i had a cv boot fitted by the guys in work a good few weeks back. Hopefully this will sort it.
Dan.
