Doorcard removal info
Can someone post detailed instructions on the removal of the doorcard. Car is 2001 3 door. Dont want to go snapping clips etc.
Thanks for info!
Andy
Rob
Easy to remove....
First off remove the speaker cover and remove/unplug the speaker....
Remove the grab handle torx screw, a t20 or t25 from memory (its often under a black cap, use a small screw driver to get this up), then the torx screw behind the interior opening handle, this is bigger, a t30 or t40, then there are 4 or 5 t20 or t25's that run along the bottom of the door.
Then the door card pulls stright out, (you'll hear a couple of clips pop open) then pull it up a bit, as it's slid into a little grove along the line of the window.
Very easy really, I've probably made it sound more complicated than it is.
Done :)
I'm seriously impressed at the lengths you must have gone to to find this thread.
