PH1 172 Sport
On the way home today I noticed that my drivers mat and the carpet are soaked. When I got back the carpet came up and the yellow soundproofing underneath is like a wet sponge!
First thing I did was check the door seals which seemed fine so out come the hose! I sprayed the water in every direction I could aiming at the door and no water got passed the seals into the car. I couldn't locate where is was coming in so Ive left the carpet up with the hope that it drys!
Ive tried a search and from what I can tell its probably the drains under the scuttle panel that are blocked or possibly the aircon drain pipe?
I took the drivers side scuttle panel off but couldn't see any drains. To find them do I need to remove everything in there? Also where is the aircon drain pipe?
I'm going to give a service tomorrow weather permitting so just need some help in pinpointing this leak.
Hope someone can help
