dynamique electrical problems
Car  Clio
rite then i would really love some light shed on my electrical problems
1. horn just does not work i think its the airbag end (common fault??)
2. 3rd brake light in spolier works now and then and when it does its really dim (maybe and earth problem)
ive take the light out of the spolier and sparyed wd on the swicth/ connection
if anyone has had any of these problems or have a soloution id really like the help
many thanks Tez ....
with the horn not working have you checked the fuse? could be an actual fault with the horn it's self as we've had a few of those,
the brake light not working well or just not working could be the actual light it's self as they are leds and once water gets in them, quite often they f**k up basically, start shorting out etc
i think they are £25 from reno
its working just not bright, i think your rite water must be getting in there
as for the horn it worked last night out of the blue then stopped working when i mover the wheel
cheers
