Easiest way to remove a Sheared stud (manifold/cat)
Car  Tweaked Leon Cupra R
Trying to get my decat on while my gearbox is out and the subframe is down but had to shear the heads off the nuts to get the cat off.
I now have the remainder of 3 studs (about 10mm long) coming out of the cat flange on the manifold..
I've left it soaking WD overnight so will have another go after work.
I've also got a dremmel if i need to get in and try drill it out but thats my last resort.
Any ideas?
I have no oxy-acetalene btw.. :(
You mean you've just got the studs sticking out, with no nuts on?
Decent pair of molegrips on it really tight?
