Ecu , uch and broken ignition barrel
finch wxm
  clio 172
I have a dodgy ignition key barrel , assuming there are no issues installing a different one ? I have 3 sets of locks and ecu and uch modules .
Aslong as the ecu and uch are matching pair ?
finch wxm
  clio 172
The key fob snapped of the key blade , but assuming i could put the chip in a new casing ? Had to get the pliers on thr key balde as it was jammed in order to remove barrel.
I have a full lock set on my iceberg so was planning to fit this to my white build as i dont have the door locks anyway.
The imobiliser ring arent coded are they ?
Just ecu , uch and keychip need to be a matching set ?
