Electric to cable throttle conversion?
Car  F4r'd Clio 1.2 16V
Hello,
After many faults with various things to do with the electric throttle I was wondering what would be required to go back to the old school cable throttle on a 172 ph2?
At a guess I would presume I need the
172 throttle body
cable
ecu
engine loom
sensors of some sort
pedal
any info would be appreciated,
and before people start, I'm not looking for better throttle response I personally would rather have cable that's all.
jack
Cannot be done on a phase 1B/2 Sirus 34 unit i'm afraid as they're "pinned" and deigned to run drive-by-wire even if you managed to re-flash the unit with Ph1 software then there would be the additional wiring work. You could maybe do it with a decoded Phase 1 Sirus unit and a engine bay loom but again there will be differences in the loom pin schematics and lets be honest here the time, effort and cash spent will gain will you nothing but "meh" (IMO of course). I'm not one for telling people how to spend their cash but seriously, i'd urge you to not start down this path and just buy a Phase 1 if you must have it... it's not like they're expensive anymore.
I've had the 172 Cup converted to cable throttle and you'll need a stand alone ECU, if it's just for the above reason then as Mick has said tbh not worth it get a PHase 1, mines been done ready for mods in the future a the car is used for sprinting as a road going car.
Regards Russ......
It can be (and has been) done, R-sport use to sell a conversion kit years back
Fred, i can't see how it woukd be possible as the Siemens Sirus 34 (on the DBW firmware) doesn't have a physical pinned input for a TPS only pedal track 1 and track 2 from the potentiometer.
The only way I can think it could be done in the case of the X65 would be to run the V6 input switch which takes a cable driven sensor and converts it to a signal the ECU interprets as the two track values... but that's still not a true cable actuated TB setup.
Are you sure it was just a patch lead and not an ecu to?
