Hi folks, I was hoping someone on here might be able to help as I'm having some serious issues with my electrics/warning lights.... car is a Ph1 172 with RS tuner map
It started about 3 or 4 months ago when my head lights went out completely and a number of lights flashed up on the dash but when I turned the headlights off and on again at the stalk everything was good again. This happened another couple of times over the space of a month or two. Oh and the radio cut out at the same time.
Then the problem started getting worse as the headlights will now only work on dipped beam, although both the green and blue (dipped and full beam) lights come on. Along with this the radio will intermittently cut off and the lights on the radio panel will start pulsing slowly, along with the heater control lights etc. Also the serv, airbag, abs and handbrake lights would come on at the same time. I should also note that the car has a hid light kit fitted.
Now in the last few weeks its got even worse, the serv and abs lights are on all the time, and at the weekend the engine management light was also flickering when I started the car to move it out of the way. The radio was still going off intermittently (some times every few minutes and other just the odd time) and also the fan would sound like it was 'pulsing' along with the lights on the heaters controls and clock/radio display. If I turned the fan up and then off the radio comes back on! The airbag and handbrake lights also come on intermittently.
Sorry for the long post but I just wanted to give a full explanation of the symptoms. I've had a search about on here and checked all the fuses etc but was hoping for some advice - could it be the ECH? I checked the voltage and the alternator seems to be working fine, and the battery is also pretty new. The car also runs well and feels fine mechanically. Sometimes it seems like the radio cuts out more if I rev the engine harder.
Any advice would be greatly appreciated, or is there anyone in the Aberdeenshire or Highlands areas who would be able to help out with diagnostics software for some beer tokens? or recommend a decent garage to give it a once over?
Ross
Ross
